It is currently Wed Aug 20, 2025 4:55 am
PostPosted: Sat Mar 29, 2014 2:06 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Thanks to all the forum members who have posted their experiences bending bubinga sides. I just finished bending a set and they turned out fine in large part because I had the benefit of reading those posts and knew what to look out for going into it. I have a back and sides set with pretty wild waterfall figuring so I was expecting the bending to be a challenge. I went straight to treating the sides with Super Soft. Didn't even attempt to bend without it based on what I had read. I following the instructions on the bottle and bent the first side about 24 hours later on my hot pipe. I lightly spritzed the inside surface with water on the tight bends. I didn't get any cracking but did get a little bit of faceting. Of course one of the facets fell dead center in the waist bend so I had to shift the bend points to get the facet off of the tightest part of the bend. I did a second application of Super Soft directly on the facet and clamped the side in the body mold overnight and that took care of it. I also did a second SS application on the bookmatched spot on the unbent side and left it overnight. That seemed to help when I bent the second side the next day. The tight bends at the waist and the upper bout took quite a bit of force to bend. I was really leaning into the pipe using narrow wood blocks to concentrate the pressure close to the bend point. The sides were 0.08 thick.
This site is a great resource for someone like me just getting into building guitars. Thanks again.
PostPosted: Sat Mar 29, 2014 2:24 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Good job! That's really a nice looking set; should make a beautiful guitar.
PostPosted: Sun Mar 30, 2014 9:27 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
'Atta boy, Jay!
I have bent quite a few sets of figured bubinga in my fox bender using SSII without drama.
Glad it worked out for you on the hot pipe.
Nice shape you have chosen - is it OM size?
PostPosted: Sun Mar 30, 2014 7:21 pm
First name: Jay
City: Bothell
State: Washington
It has a 15 inch lower bout so I think that puts it in OM size territory. It's a shape I came up with. Here's a photo of one I'm about to start putting the finish on. It's sitka/mahogany with tortoise binding.
PostPosted: Tue Apr 01, 2014 12:28 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Very pretty wood!!
PostPosted: Tue Apr 01, 2014 2:15 pm
Last Name: Sollod
I like the shape Jay!
www.swiftcreekguitars.com
